The car starts up good, idles fine with a slight miss. Once I try to go forward or reverse it stalls. I have replaced plugs, plug wires, air filter, fuel filter, and I have checked the gas pressure w/guage and it is within specs at 40PSI and only drops three PSI with engine running. Map and mav sensors are good. Can you help?
SPONSORED LINKS
Sunday, July 19th, 2009 AT 11:08 AM
