2005 Chevy Aveo New engine in my car and it wont start
STEFANIE_55
  • 2005 CHEVROLET AVEO
Engine Mechanical problem
2005 Chevy Aveo 4 cyl Manual
Hi, I just put a new engine in my car. But after we connected everything back up and tried starting it, it wont start. The starter is working when I try and start it and there is fuel going to the engine, but it seems like its not igniting. What could be the problem?
Monday, October 11th, 2010 AT 12:50 AM
Do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
Tuesday, April 18th, 2017 AT 4:31 PM
