2005 Chevy Aveo Is this a reasonable estimate to fix my car
ANGELHONIEY1123
2005 Chevy Aveo 4 cyl Automatic 67000 miles
Recently the check engine light came on in my car. I got some new tires at PepBoys and they told me that it was just the 02 sensor and it would cost me 180 bucks to fix. I decided not to go there because the last time I took a previous car there for the same problem, it was never fixed. I took it to another place and 500 dollars later the check engine light stayed on. So I figured I would take it to the dealer.
The dealer said that it had a faulty air temperature sensor and and needed an 02 sensor. Chevy said it would cost 619 dollars to fix the two. My question is this: Is this a reasonable estimate or do I risk taking my car to pepboys bc it will be cheaper?
Also, I need a tail light and they told me it was 350 dollars plus labor. I went online and I can get a tail light for 50 bucks? Is this normal?
Thanks!
Jun 15, 2010 at 9:49 AM
BLUELIGHTNIN6
  • 16,542 POSTS
that is outrageous pricing...you can buy both of those sensors (oxygen and air ) for around $225 and it shouldn't be more than $50 in labor which is total of around $275.. definitely would not pay the $350 for the taillight assembly either, sounds like they are really trying to stick it to you..
Jun 15, 2010 at 10:01 AM
ANGELHONIEY1123
Thanks, I had a feeling that it was pretty outrageous, I guess I am just so hesitant about taking it elsewhere because I don't know any trusty mechanics, and like I said in my last post, I had similiar problems with a ford and pep boys and a local mechanic were not able to fix those problems. That is why I am hesitant to take it elsewhere. But considering what you said, I am definitely being ripped off and I don't like that!
Thanks for your reply.
Jun 15, 2010 at 10:28 AM
