smoke from tail pipe
10,105 MILES
CYNTHIA YONAN
My son added 1qt of oil to the car. it is in need of an oil change. When I drove it this morning the the hold button was on and I pulled over, put the car in park and reset the hold button then got back on the highway. When I accelerated, whitish gray smoke billowed from the tailpipe. I drove it slowly home. Oil is light brown in color, trans fluid was changed 2 moths ago. Engine was rebuilt at 50000 miles. New pistons and rings were put in then. I have always maintained the engine properly. I got home turned off the car, let it sit, restarted it and when I reeved the engine the smoke continued to blow out the tail pipe. Could it be from over filling the oil or because it needs an oil change and the oil filter is bad?
Apr 30, 2013 at 7:04 AM
CARADIODOC
  • 34,414 POSTS
One extra quart of oil isn't going to hurt. Neither is neglecting a scheduled oil change. It sounds like the cylinder head gasket is leaking or the head is cracked. Coolant leaking into the combustion chamber through a leaking head gasket or cracked head causes white smoke from the tail pipe. Your mechanic can do a chemical test at the radiator to verify a leaking head gasket.
There is nothing you can do to cause a leaking head gasket, other than possibly overheating the engine, but failing to replace the engine coolant every two years might make the problem show up a little sooner. Acids normally form in the coolant and the corrosion inhibitor and water pump lubricant additives wear out in about two years. That's when those acids start to work on metal parts including the head gasket.
If you still have the red Dex-Cool, ("Dex-Mud") antifreeze in the system, GM advertised that as "lifetime" coolant to make the cost of maintenance appear lower than their competitors. Hidden on the reservoir they snuck in the three-year replacement recommendation. Even that is too long.
Apr 30, 2013 at 8:01 AM
