The Chevrolet dealer checked the vehicle over and then changed the motor mounts out and the transmission mount. The vehicle has a vibration in it. In neutral it is not noticeable, when it is put ion gear you can feel it at idle and up to 60 miles per hour. What could cause this problem. Harmonic balancer,
Flex plate, torque converter, drive train or rear end?
Mar 4, 2010 at 1:04 PM
