2002 Chevy Avalanche Fuel Starvation
2002 CHEVROLET AVALANCHE
150,000 MILES • V8 • 4WD • AUTOMATIC
SBOTES
My Avalanche 2500 with the V8 engine will run about 1-2 miles and then loses power. It will stutter along for a bit and then may regain power. It will repeat this cycle almost for as many times as you have patience for. Although unless I turn the engine off the run time between failures gets less and less.
I have found that stopping, turning car off and then re-starting works like magic, for another 1-2 miles. Better yet, if I open the gas cap and leave it loose I do not have any problem at all.
There seems to be a relationship to the gas gauge. It is not working properly. However, when it suddenly drops from 1/2 tank to empty and turns on the low fuel indicator the car will run okay WITH the gas cap tight. Gauge starts to read half full and I must loosen the cap.
I have replaced fuel filter, fuel pump and the sensor on the air intact that is located just after the air filter. I have checked the air filter it is okay. I have added injector cleaner with no changes.
One last note. This all seemed to start after I ran out of gas. The gas gauge was not working. I ran out. Got towed and refueled. Ran several hundred miles over two days and then the engine quit and would not start. The garage diagnosed a fuel pump problem. They replaced the pump which did not fix the gauge although I have better fuel pressure and now the car does not quit when the engine problem occurs.
No codes have been thrown.
Where should I look next?
Jul 18, 2008 at 8:05 AM
MERLIN2021
  • 17,250 POSTS
Chevy has a recommendation to use "Top Tier Detergent Fuel" in thier vehicles, due to injector clogging issues, so it may be that some dirt got into several of the injectors, and may need a good injector cleaning. The next thing would be the try changing your gas cap, may not vent correctly....
Jul 18, 2008 at 8:21 AM
DOCFIXIT
  • 18,828 POSTS
You very likely sucked up debris when it ran out, that's what took out the pump. I assume the shop did not flush the fuel system and pressure clean injectors.
They also should have replaced the fuel sender since it is the tank attached to the fuel pump.
So have system flushed and injectors cleaned and that should solve problem.
As for the cap when you open does it expell air?
Jul 18, 2008 at 8:30 AM
SBOTES
Yes, the cap makes a lot of noise that sounds like air being expelled. However, I do not know if it is in or out going.
I thought about the debris issue but the turning off of the engine and then starting right back up as if there is no problem and in particular the fact that I can drive all day long if the gas cap is loose makes me think that it is related to air pressure somehow in tank. I have experimented by stopping the truck and tightening the gas cap and almost immediately it will start to stall, immediate being 1-2 miles
Jul 18, 2008 at 8:52 AM
DOCFIXIT
  • 18,828 POSTS
There is pressure build up in tank you need to have the venting to tank checked out . It should be venting to a charcoal canister and into engine. I assume this all started after the pump? If yes go back there and have them check their work. If they crimped a vent line or failed to hook it up thats the problem. Did they know about the fuel gague? If so I'd have a bone to pick.
Good luck
Jul 18, 2008 at 9:01 AM
SBOTES
Yep they knew about the fuel gauge but said that the sensor was part of the fuel pump and that it would all be replaced. Wonder if the pressure build up has an affect on the sensor.
Jul 18, 2008 at 9:15 AM
MERLIN2021
  • 17,250 POSTS
SYSTEM & COMPONENT TESTING -2002 Chevrolet Avalanche 2500
Page 1 of 1
NOTE: DO NOT perform this procedure unless instructed by EVAP diagnostic test.
NOTE: Use EVAP Pressure/Purge Diagnostic Station (J 41413) in order to provide a clean, dry, low pressure gas source. DO NOT substitute any other pressurized gas source. Damage may result to EVAP system.
Inspection Procedure
1.Turn OFF the ignition. 2.Remove EVAP canister purge valve. 3.Lightly tap EVAP canister purge valve on a hard surface. 4.Inspect for carbon particles exiting either vacuum port.
 If no carbon particles were detected, install original EVAP canister purge valve and continue with cleaning procedure.
 If carbon particles are found during inspection procedure, replace EVAP canister purge valve and continue with cleaning procedure.
 If you were instructed to replace EVAP canister purge valve and no carbon particles are found, return to EVAP diagnostic procedure that directed you here. DO NOT perform EVAP cleaning procedure.
Jul 18, 2008 at 11:15 AM
KIMBERLYANDJIM
  • 10 POSTS
I have been having a very similar problem with my 02 Av. Were you ever successful in fixing the problem?
Oct 11, 2010 at 4:23 PM
MERLIN2021
  • 17,250 POSTS
To get an answer on this question, click on the email button next to their name and send an email!
Oct 18, 2010 at 3:49 PM
KIMBERLYANDJIM
  • 10 POSTS
Your message did not help at all. While I appreciate you are trying to make money with this website, I must now make 10 posts to be able to initiate a private message. I guess this is post number 2.
Oct 18, 2010 at 5:21 PM
KIMBERLYANDJIM
  • 10 POSTS
In the past, and since buying this 2002 Avalanche, I've always bought new cars. This Av reminds me why I do so. Post 3.
Oct 18, 2010 at 5:22 PM
KIMBERLYANDJIM
  • 10 POSTS
This is what my dad always told me, but no, I couldn't listen, I bought a used car and now I can't drive it more than 12 minutes before I find myself at the side of the road. Post 4.
Oct 18, 2010 at 5:23 PM
KIMBERLYANDJIM
  • 10 POSTS
See, the real problem is that my wife is the one that drives this car and I don't like the fact that she could be stuck on the side of the road.
Post 5.
Oct 18, 2010 at 5:26 PM
KIMBERLYANDJIM
  • 10 POSTS
I realize that this is not how you intended for me to make my 10 posts, but you see, I am not a mechanic, and for me to provide 10 posts helpingother peopleout, well, that would just be ludicrous. I would hurt more than help. Better that we just make this post number 6.
Oct 18, 2010 at 5:28 PM
KIMBERLYANDJIM
  • 10 POSTS
We'll see. At this point, now in post number 7, I am considering just throwing in the towel and selling the truck. It's like we only have one car anyway.
Oct 18, 2010 at 5:29 PM
KIMBERLYANDJIM
  • 10 POSTS
Since I really like the look of the truck and since it runs really well after the initial 12 minutes, I am going to keep it. Post 8.
Oct 18, 2010 at 5:42 PM
KIMBERLYANDJIM
  • 10 POSTS
By the way, it is white - post 9
KIMBERLYANDJIM
  • 10 POSTS
The bed covers. Really!?! They fade so bad, but I have found some products that keep them looking nice, post 10. Now I can stop wasting your server space and send the private message that will hopefully help to solve my problem.
Oct 18, 2010 at 5:46 PM
MERLIN2021
  • 17,250 POSTS
Instead of wasting your time with the ten post thing, Tell me in as much detail what your problem is, when it began, if any special curcummstances need to be happening for the problem to occur, what engine size, and mileage, any aftermarket electronics or perfomance parts are installed?
Oct 19, 2010 at 3:47 PM
