Is the purple wire (HO2S) the signal wire? The O2 sensor was the following wire; purple, tan, pink, & black.
Mar 20, 2010 at 2:21 AM
RHALL77
✓Experienced Mechanic
may i ask what trouble code you are getting and what the problem is your having
Mar 22, 2010 at 1:20 AM
RRRLASTF
MEMBER
I'm trying to hook a electronic fuel injector enhancer (efie) to the signal wire on the oxygen sensor.
Mar 27, 2010 at 1:01 AM
RHALL77
do you have any information on the electronic fuel injector enhancer
Mar 27, 2010 at 1:12 AM
RRRLASTF
MEMBER
the truck O2 sensor has; ppl to HO2s HI, tan to HO2S LO, pink to fuse, black to grnd. Dual digital efie from 3rdbrakeflasher has; grnd, 12v, blue & brn for 1 signal wire, white & green for 2nd signal wire. Cut O2 signal wire & connect to efie, blue going to ECU and brn to O2 sensor. Which wire am I suppose to use the purple (HI) or the tan (LO) signal wires?
Mar 27, 2010 at 2:28 AM
RHALL77
who makes the enhancer? Let me try to look up the info
Mar 27, 2010 at 2:31 AM
RRRLASTF
MEMBER
3rdbrakeflasher.com makes the efie, but the question is which signal wire do I hook the efie to the oxygen sensor.
Mar 27, 2010 at 11:23 AM
RHALL77
I never messed with one of them before, I would suggest contacting them for more information. let me know what they say
