Hey, SW I remember this guy at Woodstock when he gave Carlos and Jimmy the doby-while Carol was doing her tunes. I thought it was Eric. It was a rocking place that day. Peace
Puff of smoke during initial start normally caused by worn out valve guides/seals and the oil will find its way in the combustion forming as carbon deposits raising the compression that will cause preignition and detonation.
He knock 13/45 due to contamination by changing it but 45 relates to the ESC equivalent to the old style of the canister's vacuum/centrifugal on a conventional distributor with contact points. A problem within the ignition advance and accelerator pump which is now known as the TPS will cause an hesistation and surging problem. Also to exagerate his problem could be a clogged-up converter bcuz of the snitchers are not working ruined by the oil.
Back in the 20th Century the CEL/MIL/SES along with its Parameters/Actuators was introduced to expedite diagnosis within the Electronic Engine Control as Ford calls it and GM with the CCC system. This is the starting point of troubleshooting back then and today it never changed. In todays technology the car is like talking to the tech thru electronic devices.
Aug 22, 2007 at 11:26 PM
