2000 Chevy Astro Security Light No-Start Fix
SCTCN2
I have a 2000 Chevy Astro Conversion van with 165,000 miles and a we recently had to replace the ignition. The new ignition is in place and turns the motor over but it won't start. I have noticed that there is now a "Security" light on the dash-board now. Do you have any suggestions on how to reset this security feature? I believe what is happening is that when I replaced the ignition, the computer shut off the fuel system as a security feature. Only problem is I have no idea how to reset this system. Can you offer me any suggestions?
Sep 27, 2007 at 1:43 PM
BMRFIXIT
  • 19,053 POSTS
you need to program the new ignition so that
the ECM alow the fuel throw the injectors
Sep 27, 2007 at 2:11 PM
SCTCN2
How should we go about programing the new ignition?
Sep 28, 2007 at 10:14 AM
Suggested Repair
Program the new ignition so the ECM allows fuel through the injectors.
Conversation Summary
A 2000 Chevrolet Astro cranks but will not start after the ignition was replaced, and the security light is on. The owner believes the security system has shut off fuel. The expert says the new ignition must be programmed so the ECM allows fuel through the injectors. No programming steps were provided.
