1992 Chevrolet Astro Fuel Pump Failure
XCONSTANTEP
I own a 92' astro van 4.3L with 132000 miles, the 8th letter is a W. I started having problems with the start, have to wait a few seconds with the swith open and then started, but the car emited a lot of dark exhaust gases, so I took it to a friend and he noticed that the fuel pump and the regulator were in bad conditions so I changed them, also with the injector vortec. After that the car started good, and run smooth and fast, but the light engine repair soon lighted up, the next day the car did not start so I towed it to a dealer. They say that the fuel pump is only pumping 10 psi, so they changed it, and when I saw the pressure with the test gage was 45 psi, also they say that the fuel regulator is bad. Please, would you tell me what happened? why the fuel pump and fuel regulator within 1 day just died?? what is the cause that these elements just spoiled?
I appreciate your expertise and your answer
thank you
Xavier
Oct 30, 2007 at 4:18 AM
BMRFIXIT
  • 19,053 POSTS
[quote:0ca7a5b965="xconstantep"]I own a 92' astro van 4.3L with 132000 miles, the 8th letter is a W. I started having problems with the start, have to wait a few seconds with the swith open and then started, but the car emited a lot of dark exhaust gases, so I took it to a friend and he noticed that the fuel pump and the regulator were in bad conditions so I changed them, also with the injector vortec. After that the car started good, and run smooth and fast, but the light engine repair soon lighted up, the next day the car did not start so I towed it to a dealer. They say that the fuel pump is only pumping 10 psi, so they changed it, and when I saw the pressure with the test gage was 45 psi, also they say that the fuel regulator is bad. Please, would you tell me what happened? why the fuel pump and fuel regulator within 1 day just died?? what is the cause that these elements just spoiled?
thank you
Xavier[/quote:0ca7a5b965]
U can blame it on one or two things the installer and or bad parts
Oct 30, 2007 at 12:46 PM
Suggested Repair
Suspect incorrect installation and/or defective replacement parts. Recheck the fuel pump and regulator installation, confirm fuel pressure, and use quality parts.
Conversation Summary
The owner of a 1992 Chevrolet Astro with a 4.3L engine had hard starting and dark exhaust. After replacing the fuel pump, regulator, and injector, it ran well briefly, then the check-engine light came on and it would not start. The dealer found only 10 psi from the pump, replaced it, measured 45 psi, and said the regulator was bad. The expert attributes the rapid failure to the installer and/or bad parts.
