fuel pump
JEJORO64
I have a astro van 2003, 60,000 miles,there is no power at fuel pump I have checked fuses and relay also provide power from battery to the conections of the relay and nothing, the fuel pump haven't received any power, and I can't find a safety switch, thank you.
Jul 20, 2007 at 10:28 AM
  • 75,988 POSTS
[quote:6af512cd31="jejoro64"]I have a astro van 2003, 60,000 miles,there is no power at fuel pump I have checked fuses and relay also provide power from battery to the conections of the relay and nothing, the fuel pump haven't received any power, and I can't find a safety switch, thank you.[/quote:6af512cd31]
Do you have power at the brown wire on the relay-if not the problem is coming from the PCM
Jul 20, 2007 at 5:23 PM
