2003 Chevrolet Astro No Fuel Pump Power
JEJORO64
I have a astro van 2003, 60,000 miles,there is no power at fuel pump I have checked fuses and relay also provide power from battery to the conections of the relay and nothing, the fuel pump haven't received any power, and I can't find a safety switch, thank you.
Jul 20, 2007 at 10:28 AM
  • 75,988 POSTS
[quote:6af512cd31="jejoro64"]I have a astro van 2003, 60,000 miles,there is no power at fuel pump I have checked fuses and relay also provide power from battery to the conections of the relay and nothing, the fuel pump haven't received any power, and I can't find a safety switch, thank you.[/quote:6af512cd31]
Do you have power at the brown wire on the relay-if not the problem is coming from the PCM
Jul 20, 2007 at 5:23 PM
Suggested Repair
Check for power at the brown wire on the fuel pump relay. If that wire has no power, the fault is coming from the PCM.
Conversation Summary
The owner of a 2003 Chevrolet Astro with 60,000 miles reports no power at the fuel pump after checking the fuses and relay and applying battery power to the relay connections. No safety switch was found. The expert advises checking power at the brown wire on the relay and says that if power is absent, the problem is coming from the PCM.
