1997 Chevy Astro Van 6 cyl, 4.3L engine, 128,000 miles
The van shut itself off while driving down the street the other day. Will still crank fine, but not start.
Unable to read trouble codes, probably because the OBD-II connector is only showing 0.7 volts across pins 4 and 16.
Do these two data points (shut down/no re-start and low connector voltage) pin down the point I should check next?
Feb 17, 2007 at 1:36 AM
