1997 Chevy Astro No Start
WASTAMPS101
1997 Chevy Astro Van 6 cyl, 4.3L engine, 128,000 miles
The van shut itself off while driving down the street the other day. Will still crank fine, but not start.
Unable to read trouble codes, probably because the OBD-II connector is only showing 0.7 volts across pins 4 and 16.
Do these two data points (shut down/no re-start and low connector voltage) pin down the point I should check next?
Feb 17, 2007 at 1:36 AM
MATHIASO
  • 1,209 POSTS
On many vehicles the computer 's system voltage comes from a relay or fuse.The system voltage should never be less than 9 volts while the starter is cranking the engine nor greater than 15 volts while the engine is running.If the voltage is not within the 9 - 15 - volt range, some computer will shut themselves down.
check the relay or fuse.
also inside the computer is a voltage regulator which reduces the system voltage to a constant reference voltage of aproximately 5 volts. No matter what the system voltage, the reference voltage will allways stay constant. The voltage regulator's second purpose is to shutt off curent flow if there is a short circuit.This may have caused high curent flow in the circuit and the computer will not work untill the sensor is replace.Follow the manufacture's recommende diagnostic procedure to locate the bad sensor and do not make quick decision to replace the computer .
Feb 17, 2007 at 4:07 AM
Suggested Repair
Check the computer power relay and fuse and confirm system voltage stays between 9 and 15 volts. If a shorted sensor caused the computer to shut down, follow the manufacturer's diagnostic procedure to find the bad sensor before replacing the computer.
Conversation Summary
A 1997 Chevy Astro with a 4.3L engine shut off while driving and cranks but will not restart. The OBD-II connector shows only about 0.7 volts across pins 4 and 16. The expert advised checking the computer power relay or fuse, verifying system voltage, and diagnosing a possible shorted sensor rather than immediately replacing the computer.
