chevy astro 1990 87,000 4.3 auto transmission.
problem when putting van into forward gear ( reverse good ) to get van to move the engine has to be sped up and then it crashes into gear and starts moving. At highway speeds there is a loud whistling coming from the transmission area. Could this be a vacuum leak from where the control module plugs into the transmission ? Broken o-ring on plunger ?
Thank you,
James E. Dysert
Thank you,
James E. Dysert
Nov 16, 2007 at 3:59 AM
