2000 Chevy Astro Hard Shift
195,000 MILES • 6 CYL • AWD • AUTOMATIC
ABUFFALOW
After about 50 miles of driving I get a semi-hard shift from 1st gear to 2nd gear. Every other gear shift is smooth. Could this be a flush & change screen solution or something more complicated? Thank you!
Jun 14, 2010 at 8:13 AM
  • 110,251 POSTS
It could be. I recommend doing that to see if it helps. But in addition, there is a shift solenoid in the transmission (on valve body) that could be the problem too. To save the money of having to remove the pan twice and paying for the gasket and fluid 2 times, I would replace the solenoid too to see if that takes care of the problem.
Jul 19, 2010 at 4:12 PM
