1993 Chevy Astro Transmission slipping
1993 CHEVROLET ASTRO
12,000 MILES • 6 CYL • AWD • AUTOMATIC
GABSDAD8
The transmission in my Astro has just begun to slip, but only in the "D" gears. It doesn't slip in 1 or 2, or in reverse. Trans. fluid looks good, doesn't smell burnt, and the level may be a little bit high.
Any suggestions on what I can do to keep this thing movong a little bit longer?
Thanks, Bill
Jun 17, 2009 at 4:08 AM
DOCFIXIT
  • 18,828 POSTS
Hi Is it slipping in 4th or OD ? will it not slip if in 3rd?
Maybe a shift solenoid or torque convertor solenoid.
A scan of trans would tell if solenoids and sensors good.
Hope this help
Thanks for donate
Jun 17, 2009 at 7:26 AM
GABSDAD8
Thanks for your reply. It slips only in OD and D., 2,1 and reverse are fine. I drained some fluid out (it was a little overfilled), but that didn't help. How do I "scan" my transmission? Does that need to be done at a trans. shop?
Jun 17, 2009 at 12:49 PM
DOCFIXIT
  • 18,828 POSTS
Scannig must be done at a repair shop that has the equipment.
Jun 18, 2009 at 2:45 AM
GABSDAD8
Thank you!
Jun 18, 2009 at 2:59 AM
DOCFIXIT
  • 18,828 POSTS
Let me know what they find and will advise if repair seem right.
Jun 18, 2009 at 3:03 AM
GABSDAD8
Thanks again.
Jun 18, 2009 at 3:27 AM
