alignment
CHEVROLET ASTRO
BUTTONMAN21
1 HAVE A '95 CHEV ASTRO VAN WITH APPROX. 122,000 MI. THE INSIDE FRONT TIRES ARE WEARING EXCESSIVELY, ESP THE RIGHT TIRE. THE STEERING PULLS SHARPLY TO THE RIGHT. I HAVE TALKED WITH OTHER ASTRO OWNERS THAT HAVE THE SAME PROBLEM BUT THEY HAD NO SOLUTION. THE LAST TIME I HAD AN ALIGNMENT I WAS TOLD THAT MY ALIGNMENT WAS MAXED OUT. HOW DO I CORRECT/ELIMINATE THIS PROBLEM?
Sep 30, 2007 at 8:48 PM
BOOTDOG
  • 665 POSTS
i would still have the alignment checked out at least once more, just to see where the camber and toe are at. if the camber is maxed out then you'll probably need to start replacing parts. i.e. springs and shocks. weak springs can make your ride height a lot lower. the pulling is probably due to the tires being worn. anyway good luck
Oct 1, 2007 at 5:36 PM
