The brakes and power steering went out at the same time, I have an astro 1996 chevy van. Any idea what could be the problem
Friday, September 7th, 2007 AT 4:04 PM
MERLIN2021
MECHANIC
Check the power steering reservoir, Your van has the hydro-boost power booster, it runs off the power steering, not vacuum! Check fluid and belts.
SPONSORED LINKS
Friday, September 7th, 2007 AT 4:59 PM
SUGARPEA421
MEMBER
I have already checked all of that could it be a fuse
Friday, September 7th, 2007 AT 5:03 PM
MERLIN2021
MECHANIC
Not likly. Think power steering pump.
Friday, September 7th, 2007 AT 8:47 PM
SUGARPEA421
MEMBER
What is a good way to check if it is the power steering pump?
Saturday, September 8th, 2007 AT 9:04 AM
MERLIN2021
MECHANIC
Disconnect a high pressure hose and plce end in a bucket, have a helper start the car, fluid should come out of the hose with a lot af force! Be prepared to turn on and off quickly!
