1993 Chevy Astro Headlights Out
SIRHC0329
I need a little help locating the headlight relay on my 93 astro van. I think this is the right part- my problem is: i would turn on my headlights and the headlights would go out but the parking lights would stay on, then the headlights would come back on then go back off. Now they have quit coming on alltogether and parking lights aren't enough. Any help would be appreciated. Thank you in advance.
Oct 27, 2007 at 1:17 PM
BMRFIXIT
  • 19,053 POSTS
[quote:9acdeb9d19="sirhc0329"]I need a little help locating the headlight relay on my 93 astro van. I think this is the right part- my problem is: i would turn on my headlights and the headlights would go out but the parking lights would stay on, then the headlights would come back on then go back off. Now they have quit coming on alltogether and parking lights aren't enough. Any help would be appreciated. Thank you in advance.[/quote:9acdeb9d19]
your DRL relay on the left rear corner of engine comprtment on fire wall
and fog relay behind left side of dash
also check head light switch and the connector
good luck
Oct 27, 2007 at 3:28 PM
SIRHC0329
[quote:c8e02e741e="BMRFIXIT"][quote:c8e02e741e="sirhc0329"]I need a little help locating the headlight relay on my 93 astro van. I think this is the right part- my problem is: i would turn on my headlights and the headlights would go out but the parking lights would stay on, then the headlights would come back on then go back off. Now they have quit coming on alltogether and parking lights aren't enough. Any help would be appreciated. Thank you in advance.[/quote:c8e02e741e]
good luck[/quote:c8e02e741e]
Thanks alot man! it was the headlight switch, up and going again. thanks again
Oct 29, 2007 at 3:32 PM
Suggested Repair
Check the headlight switch and its connector. Also inspect the DRL relay at the left rear corner of the engine compartment on the firewall and the fog relay behind the left side of the dash. In this case, replacing or repairing the headlight switch restored the headlights.
Conversation Summary
The owner of a 1993 Chevrolet Astro asked where the headlight relay is after the headlights flickered off while the parking lights stayed on, then failed completely. The expert pointed to the DRL relay on the firewall, the fog relay behind the left side of the dash, and the headlight switch and connector. The owner later confirmed the headlight switch was the cause and the lights worked again.
