2002 Chevy Astro hear noise when turning
MR.GAINS
  • 2002 CHEVROLET ASTRO
  • 6 CYL
  • 130,000 MILES
When making a left turn I hear a grinding sound. What can this be?
Friday, April 2nd, 2010 AT 12:30 AM
LEGITIMATE007
  • 5,121 POSTS
Hi mr. Gains, that is mostlikely a cv joint. It will need to be replaced, eventually, however, should be done as soon as your able to afford to do it. You must check the prices first, as far as getting some estimates, be cause nine times out of ten it is actually cheaper to change the entire shaft than to just do the cv joint because it is so labor intensive to just do the cv joint
Sunday, April 4th, 2010 AT 12:34 PM
