1997 Chevy Astro clunking sound
1997 CHEVROLET ASTRO
118,000 MILES • 6 CYL • 2WD • AUTOMATIC
DANRACE
  • 33 POSTS
Hi, Well this clunking sound is coming from the suspension on the passenger side. It does it when you drive it and more noticable the last 2 days. I had this problem a couple months ago so I lubed all the grease fittings and a couple were a little dry and the sound went away and you would have to rock the vehicle pretty good to get that sound to happen. This time again you do not need to push too much to make that sound happen. I looked under there and pushed the vehicle with my foot to pin point where the sound was coming from and I just used wd40 around the area Ii heard the sound with no luck. My neighbor said It sounds like a tie rod. I even replaced the front shocks thinking that was the remedy to the problem. I am including a photo of the area in question. It is wet from me spraying wd40.
Many Thanks Dan[img:02ea9e8b4c]http://www.2carpros.com/forum/automotive_pictures/238734_IMG_0597_1.jpg[/img:02ea9e8b4c]
Sep 15, 2008 at 3:09 PM
MMPRINCE4000
  • 8,548 POSTS
I would suspect the control arm bushings. Best way is to disasemble it and inspect the components.
If you jack up the car, put on stands, and grasp the wheel moving it in and out both horizontally, and vertically, looking for any play, Have someone watch th components to isolate the problem.
Sep 15, 2008 at 9:27 PM
