2002 Chevy Astro Car wont start
POPPA4P
  • 2002 CHEVROLET ASTRO
Steering problem
2002 Chevy Astro 6 cyl Two Wheel Drive Automatic
I changed my steer gear and the car wont start.
Friday, May 21st, 2010 AT 10:22 AM
Backtrack your work unable to figure it out-do below to determine if its a fuel or spark problem.
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 in away from ground have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor /distributor pick-up coil, ignition control module, ECM, Ignitor camshaft and crankshaft sensors and computer. Note: If it doesn't apply disregard it
Sunday, May 23rd, 2010 AT 7:53 AM
