2001 Chevy Astro selector switch doesn't change air directi
2001 CHEVROLET ASTRO
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
RNDYWILLIAMS
When running the Heater/AC the selector switch will not change the air position. It stays on "Floor/Defrost at all times. It started doing this only at times, now all of the time. It also sounds like one of the "Air Ducts" is plugged up.
Dec 12, 2009 at 9:40 AM
  • CAR REPAIR CONTRIBUTOR
  • 110,190 POSTS
In this case, you are looking for a vacuum leak. The vent doors are actuated by engine vacuum. If the vacuum isn't there or is too weak, this is what happens. Check under the dash for leaks and follow the supply line to the engine to make sure it isn't disconnected or damaged.
Let me know what you find.
Dec 21, 2009 at 7:35 AM
