1999 Chevy Astro AIR CONDITIOUNING
67,000 MILES • 6 CYL • 2WD • AUTOMATIC
DAN KARTMAN
My AC works but only blows out the defrost or the bottom it will not switch to the main vents
Dec 13, 2007 at 7:55 AM
TOBYU
  • 89 POSTS
Most likely a vacuum leak. Vacuum from the engine is what the dash control uses to move the diverter flaps that change the air flow.
I think the Astros had a plastic ball under the hood....hooked to the under side of hood. This is a vacuum reservoir.
Dec 13, 2007 at 6:43 PM
