2001 Chevy Astro Blower motor
2001 CHEVROLET ASTRO
11,000 MILES • 6 CYL • 2WD • AUTOMATIC
SURFCAR
Hello
Ac is not blowing in the front part of the vehicle , it is blowing cold and with force in the back , i checked the normal fuses and see no evidence of a blown fuse but i am wondering if there is some other fuse or electrical part somewere that may not be functioning creating the problrm , or do i need to pull the blower motor becuase it is bad?
thank you
Greg
Jul 9, 2008 at 6:20 PM
JDL
  • CAR REPAIR CONTRIBUTOR
  • 16,098 POSTS
I'd get at the wiring connector for the front blower motor, take the connector loose, turn on the hvac controls, check the circuits at the connector. The black wire is ground the other should be B+. If you have good B+ and ground, with no motor action, you need to check the motor.
Jul 10, 2008 at 2:06 PM
