2000 Chevy Astro vehicle starting
D-MAN1
  • 2000 CHEVROLET ASTRO
  • 6 CYL
  • 72,000 MILES
My vehicle seems to have problems starting after it rains. Once or the next day no rain or it dries. It seems to start up with no problem. Any advice
Sunday, June 15th, 2008 AT 10:29 AM
JDL
  • 16,098 POSTS
When the vehicle refuses to start, are you saying it won't even crank, or it cranks good but won't start?
If it won't even crank, can you tell if there is a load on the battery, when you turn the key to crank? You could use a voltmeter across the battery posts, take a reading, have a helper turn the key to crank, take another reading. With the key in the crank position, the reading should drop a little.
When it refuses to crank, you could turn on the headlites, turn the key to crank, watch the lites. If they go out or almost out, it's usually the battery or cables. If the lites stay bright, when the key is turned and no starter action, there is an open circuit somewhere.
You could do some testing at the starter relay, when it refuses to crank.
Sunday, June 15th, 2008 AT 11:38 AM
