HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Astro
Engine
Symptoms
Not Running
2000 Chevy Astro Van Won't after sitting in Rain
NJASTRO
MEMBER
2000 CHEVROLET ASTRO
6 CYL
2WD
AUTOMATIC
170,000 MILES
My astro van doesnt start after sitting in the rain. On dry days it starts up perfect.
Thursday, April 1st, 2010 AT 1:45 PM
TWOSTEPPER
MEMBER
When the problem occurs, have a helper crank it, while you check for spark at the plugs. Find out what your missing, I start with fuel and spark.
Some day when it is running fine, use a spray bottle with water, mist around on the plugs wires, see if you get any reaction?
SPONSORED LINKS
Thursday, April 1st, 2010 AT 2:14 PM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
2000 Chevy Astro Van Will Not Start
Engine Performance Problem 2000 Chevy Astro 6 Cyl Automatic 180000 Miles Ok, Van Has Been Sitting For About 4-5 Months. It Ran Then...
Asked by
huckleberryhound
1 ANSWER
2000
CHEVROLET ASTRO
VIDEO
How to fix an engine that wont start
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
Engine Will Not Start?
Engine Will Crank Won't Start. Trouble Code P1351. Any Ideas What The Problem Is.
Asked by
Anonymous
1 ANSWER
1 IMAGE
2000
CHEVROLET ASTRO
2000 Chevy Astro Cranks Over But Will Not Start
Sounds Like Fuel Pump Is Working, I Can Here It When I Turn The Key. How Do You Check The Ignition Module? And How Do You Check The Fuel...
Asked by
thefrynge
1 ANSWER
2000
CHEVROLET ASTRO
2000 Chevrolet Astro Wont Start
I Try To Turn On The Van And It Wont Start, Turn Over. When You Put The Key In The Ignition It Doesn't Start At All And There Isnt A Ding...
Asked by
taylorm34
2000
CHEVROLET ASTRO
Won't Start
I Have A 2000 Astro And It Will Not Start When First Started (usually With A Jump). It Has High Mileage But Until Recently, Has Been...
Asked by
shazbah
2000
CHEVROLET ASTRO
VIEW MORE
SPONSORED LINKS
Crankshaft Sensor Replacement
Crankshaft Sensor Symptoms
Online car repair manuals
