2000 Chevy Astro front shock removal
2000 CHEVROLET ASTRO
75,000 MILES • 6 CYL • 2WD • AUTOMATIC
HULINGDR
using a deep well socket to remove top nut on front shock, entire shaft turns, have been unable to come up with a method to hold the shaft, is there some kind of trick to this?
Thanks
Apr 25, 2009 at 4:04 PM
  • 110,241 POSTS
Usually there is a place for a small socket at the end of the shock itself. You hold that with the socket and use an open end wrench on the nut you are turning. If that fails, since the shock is junk already, I will tightly clamp vice grips on the shaft to hold it. If there is a will, there is a way.
May 10, 2009 at 1:02 PM
TECHMAN1
  • 82 POSTS
[quote="hulingdr"]Suspension problem
2000 Chevy Astro 6 cyl Two Wheel Drive Automatic 75000 miles
Thanks[/quote
My God this is bad. You can not hold it with anything. I am a "never give up" mechanic. I had to take the new shocks to a muffler shop, have them cut the old ones off with a cutting torch and put in the new ones. It was not that bad. I provided the shocks and they only charged me $40.
May 21, 2009 at 3:06 PM
