2000 Chevy Astro
ALVIN LENFORD
  • 2000 CHEVROLET ASTRO
Brakes problem
2000 Chevy Astro
How to remove rear brake drum? Auto repair manual states that if the car has floating rear axles, they first have to be removed. How can you tell?
Thursday, May 14th, 2009 AT 6:32 PM
  • 109,885 POSTS
Safely lift the rear wheel and suport vehicle. Remove the rear wheel. Make sure the park brake is off. On the rear backing plate of the brake assembly, you will see an oval shaped rubber plug. Remove the plug to access the brake adjuster. Loosten the adjuster so the brake shoes close on the inside and the drum will come off. You may have to tap on it a few times to loosten corrosion and dust, but they will come off. When tapping on the drum, make sure to tap in the area if the bearing hub (as seen in the directions).
Here are directions to help. I don't believe you have a floating axle.
https://www.2carpros.com/how_to/rear_brake_shoes.htm
Let me know if this helps.
Monday, June 1st, 2009 AT 10:20 AM
