1999 Chevy Astro Fuel related problems
103,000 MILES • 6 CYL • AWD • AUTOMATIC
CLIFF48
I have a 1999 Astro van, and it will not start unless I spray starter fluid in air intake. Gas is up to fuel pressure, don't have a guage to know if it is at 60 psi. I can hear fuel pump hum. Just replaced altentor and found one spark plug wire unplugged and 1 loose, put them back on. Don't know ifproblem is fuel pump or fuel regulator. Any suggestions. Thank you for any help.
Jul 30, 2009 at 1:58 PM
DOCFIXIT
  • 18,828 POSTS
Really need to check fuel pressure with a guage.
Jul 31, 2009 at 3:24 AM
CLIFF48
Purchased a fuel pressure gauge today. Gauge reads 16 pis. I think it is suppested to be somewhere around 58 to 60, if I am correct.
Jul 31, 2009 at 3:33 AM
DOCFIXIT
  • 18,828 POSTS
Yes needs to be 60-66 psi It's time to drop tank and replace pump.
Jul 31, 2009 at 3:47 AM
CLIFF48
We were in the procress of replacing the fuel pump as I was reading your email. Van is now running, thanks much for your advice.
Jul 31, 2009 at 10:39 AM
DOCFIXIT
  • 18,828 POSTS
Great news if you needs us again where here for you
Aug 1, 2009 at 7:47 AM
