HARD SHIFTING. WOULD IT HELP TO CHANGE THE FILTER?
Wednesday, September 8th, 2010 AT 5:05 PM
MECHANIC
Hi there,
I would check the ECU for unresolved fault codes, and the service will only help, report any codes here for more assistance.
Mark (mhpautos)
SPONSORED LINKS
Thursday, September 9th, 2010 AT 4:40 AM
WHOMAN
MEMBER
What is ecu?
Thursday, September 9th, 2010 AT 8:17 AM
MECHANIC
Hi there,
ECU engine control unit, I do think you call them a PMC regardless of the terminology, you can scan the system with an OBD 11 scanner, the results will be the same,
