1998 Chevy Astro power windows
1998 CHEVROLET ASTRO
169,432 MILES • 6 CYL • 2WD • AUTOMATIC
BOB KIRBY
Having problems with the window going back up. replaced the motor, regular and switch and still having problem with window going up. Turn off car and it will reset and then will go up a little bit. Have to keep turning on and off the car. Is there a relay switch in the harness that may possibly be bad
Sep 24, 2008 at 2:09 AM
JDL
  • 16,098 POSTS
Which window are you having trouble with, the driver side front?
There should be a power window circuit breaker in the fuse box, when your having problems, feel of the breaker, is it hot. It shouldn't be hot. There maybe another circuit breaker in the fuse box, with the same amp rating, you could try switching it out. I don't usually get that lucky.
Sep 25, 2008 at 2:18 AM
