Engine Mechanical problem
1998 Chevy Astro 6 cyl Two Wheel Drive Automatic 90.000 miles
my van wont start I have spark and fuel it cranks over fine but it wont start also checked all fuses all fine thanks.
Monday, March 15th, 2010 AT 8:33 PM
MECHANIC
Check fuel pressure if it is within specs and also check for injector pulses if both okay, then check the valve and ignition timing, this will lead you to problems
with compression and valves opening and closing at the wrong time/broken or jumped timing belt/chain.
