1996 Chevy Astro No Spark
HEHONGEL
  • 1996 CHEVROLET ASTRO
  • 6 CYL
  • 159,000 MILES
At the coil there is 12 volts but no spark coming out of the coil wire. Replaced the coil still same problem, replaced the distributor with new; still same problem. Could it be the PCM? Or something else? Is there a way to test the PCM if so how
Monday, April 13th, 2009 AT 9:01 PM
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Monday, April 13th, 2009 AT 9:19 PM
