1996 Chevy Astro ENGINE DON COME ON JUST CRANK
CASTGEOR
  • 1996 CHEVROLET ASTRO
  • 6 CYL
  • AWD
  • 165,000 MILES
YES ACTUALLY MY ENGINE JUST CRANK I OPEN THE KEY AND I TRY TO MAKE THE ENGINE COMES ON AND JUST CRANK, IF I USE STARTING FLUID I CNA MAKE THE ENGINE COMES ON AND STAY ON AND DRIVE IT BUT BUT IF AM GOING UPHILL DON'T HAVE POWER I CAN PUSH THE PEDAL AND IS NOT RESPONSE, DOWN HILL NOT A PROBLEM IT ALL AND I CAN GO 80 MILES X HOUR IF I WISH, AND WHEN I TURN THE ENGINE OFF AND I LEAVE IT STAND FOR 10 MINUTES DONT WANT COME ON AGAIN I GET THE ENGINE CODE BUT AM CONCERN WHAT COULD BE IS THE P0306 I HOPE SOMEONE CAN GIVE AN ADVICE I APRECIATE ANY HELP POSSIBLE AND THANKS IN FORWARD.
Sunday, July 13th, 2008 AT 7:31 PM
Misfire at cylinder no.6 check the sparkplug, compression and injector for this cylinder-
Also check the fuel pressure with a guage confirm its within specification that's with and w/o vacuum to the pressure regulator-
Sunday, July 13th, 2008 AT 8:15 PM
