1992 Chevy Astro Dog house
BUDE106
  • 1992 CHEVROLET ASTRO
Engine Mechanical problem
1992 Chevy Astro 6 cyl All Wheel Drive Automatic
Hello; I need to take the dog house off. I have no idea how it unbolts. I have had other vans, where there are two bolt and nut assm. Accessed from under the hood, but I can not find anything resmbling a wing nut, or plain nut. Help.
Scott.
Monday, May 11th, 2009 AT 9:05 AM
ALANBIG6
  • 9 POSTS
You will have to remove the trim panel below the radio and you will find two ten mil. Nuts holding the top of the box. Then on sides of the box to the right of the accel. Pedal and pass side same height you will find spring loaded straps. Release the tension then at the floor to the left and right of the center line of the dog house you will find two more ten mil nuts. Also check for two bolts into the floor you will have to pull the carpet back to exspose.
Hope this info helps. Alan retired but it in my blood.
Tuesday, May 12th, 2009 AT 9:49 PM
