When the temp. Is above 90 and we drive the van for 30 minutes or more, it will suddenly die as if I shut off the engine with the key. After cooling for 30 minutes or more it will start and run. When the temp. Is in the 80's or lower it seems to be fine. Besides this problem, it runs perfectly.
I changed the fuel pump because it failed to put out enough pressure. I also changed the plugs, wires, distributor cap, rotor, coil.
SPONSORED LINKS
Tuesday, September 29th, 2009 AT 7:32 PM
