1996 Chevy Astro 1996 Astro Fuel Pump Electrical
ZIGGYSTAL
  • 1996 CHEVROLET ASTRO
  • 6 CYL
  • 220,000 MILES
My fuel pump is not engaging when starting the car (because I can't hear it priming). THe fuel pump is new, so I'm thinking its not getting electricity/pwer. How exactly can I check this? I've already checked the relay and it's working. Is there something beyonf the relays I can check to confirm if the pump is getting electricity?
Sunday, November 30th, 2008 AT 10:02 AM
DOCFIXIT
  • 18,828 POSTS
You should be able to get to wiring at pump check for power. The relay clicks?
Sunday, November 30th, 2008 AT 2:03 PM
ZIGGYSTAL
  • 9 POSTS
Yes the relay clicks. IN terms of the fuel pump, which wire(s) are the ones that give electricity to the fuel pump? Just so I know what cables to check. To check these am I going to have to dismount the fuel pump again?
Sunday, November 30th, 2008 AT 3:38 PM
DOCFIXIT
  • 18,828 POSTS
At the relay use a jumper wire from D2 to C3 see if pump runs. If not then check gray wire for power and black for ground.
Sunday, November 30th, 2008 AT 4:44 PM
ZIGGYSTAL
  • 9 POSTS
What do you mean by D2 and C3? Are these terminals where the relay goes in? There's 5 little terminals there, 3 on one side and 2 on the other. How would D2 and C3 apply to those?
Sunday, November 30th, 2008 AT 5:51 PM
ZIGGYSTAL
  • 9 POSTS
Monday, December 1st, 2008 AT 4:48 PM
DOCFIXIT
  • 18,828 POSTS
If it is not noted on relay or terminal. Then big red wire and gray wire. Probably one one the three side and the other on the two side
Monday, December 1st, 2008 AT 4:54 PM
