Master cylinders don't normally cause that type of problem. You probably have your parking brake cable hanging up and causing this. You may have to get a new cable so the brakes will release all the way. It could also be your adjusters are worn out on that side. Especially with the age and mileage on your vehicle. If you do decide to chang ethe adjusters make sure to get the kit and do both sides as the kit is all the springs, adjusters, and everything you need to replace it all.
SPONSORED LINKS
Tuesday, August 31st, 2010 AT 8:03 PM
