HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Astro
Brakes
Wheel Cylinder
1993 Chevy Astro wont stay running
UCKYOU
MEMBER
1993 CHEVROLET ASTRO
Engine Mechanical problem
1993 Chevy Astro 6 cyl Two Wheel Drive Automatic
car will start run for 3 to 5 seconds and then stop
Thursday, June 18th, 2009 AT 12:44 AM
BERNIEM
MEMBER
If it sputters or stops.
Try cleaning the EGR valve,
Un plug the map censer and EGR try to start it again.
If no change, might look into map Censer.
EGR censers is notorious on astros.
And Map censers as well.
SPONSORED LINKS
Thursday, June 25th, 2009 AT 10:43 PM
Please
login
or
register
to post a reply.
Related Wheel Cylinder Content
1990 Chevy Astro Creeping Brakes
Hi, I Replaced Shoes, Pads, Wheel Cylinders, And Master Cylinder And Bled The Brakes. At A Stop The Brake Creeps To The Floor. At A Stop I...
Asked by
RUDEBOY01
1 ANSWER
1990
CHEVROLET ASTRO
GUIDE
Wheel Cylinder Replacement
A brake system wheel cylinder is used to push against a set of brake shoes to help stop the car.
1995 Chevy Astro Plug Isgetting Wet With Gas
Engine Performance Problem 1995 Chevy Astro 6 Cyl Two Wheel Drive Automatic 1oo.00 Miles How Do I Get This Tostop Hapening Or What Can...
Asked by
antsdetailman
1995
CHEVROLET ASTRO
Abs Problems
Engine Idles Fine, But Rpms Rise Significantly When Put Into Fwd And Reverse ( Automatic ). This Is In A 1998 Astro With A V8 Conversion...
Asked by
redfury
2 IMAGES
1998
CHEVROLET ASTRO
Abs Issue
My Van Has An Abs Problem. It Wants To Work Every Time The Vehicle Is Coming To A Stop. Doesn't Matter What Speed Or How Hard You Press...
Asked by
jfk9600
4 IMAGES
2000
CHEVROLET ASTRO
2001 Chevy Astro Brake Lines
I Am Looking For A Brake Line Drawing From The Master Cylinder To The Electronic Control Box And Then Out To The Wheels.
Asked by
chief030
1 ANSWER
2001
CHEVROLET ASTRO
VIEW MORE
SPONSORED LINKS
Brake Shoe and Drum Replacement
Brake System Flush
Bleed and Flush Your Brake System Correctly
Online car repair manuals
