1993 Chevy Astro Hydroboost Brake Booster
1993 CHEVROLET ASTRO
148,000 MILES • 6 CYL • 2WD • AUTOMATIC
DJKRAUSE
My front reservoir goes empty quickly. I cannot detect any leaks at any wheel or master cylinder. Although when pumping the breaks, I can hear what sounds like liquid or air, going through a hose from the brake booster to the power steering reservoir . That reservoir's level doesn't change.
Aug 19, 2008 at 7:18 AM
MASTERTECHTIM
  • 4,750 POSTS
you definitely have a leak. remove rear wheels and remove drums and inspect wheel cylinders for leaks. also look under dash where braqke rod goes through firew2all for wetness, if it is replace master cylinder
Aug 19, 2008 at 12:20 PM
DJKRAUSE
you're right. once i parked on pavement and tried the brakes, i found a leak in the rear line just in front of the wheels. thanks
Aug 19, 2008 at 2:49 PM
MASTERTECHTIM
  • 4,750 POSTS
awesome
Aug 21, 2008 at 8:28 AM
