1993 Chevy Astro fuel pump
BUMPER486
  • 1993 CHEVROLET ASTRO
  • 6 CYL
  • 167,000 MILES
My motor just quit running today while I was driving. It cranks over real good but will not start. I suspect a fuel pump problem but i've also heard that there is a fuel pump fuse and relay that I should check. Could you tell me where these are located and also if my fuel pump is inside the gas tank or mounted on the outside of the motor somewhere?
Sunday, August 3rd, 2008 AT 1:44 AM
FATMAC
I have 1991 astro and fuel pump is in the tank
Sunday, August 3rd, 2008 AT 10:47 AM
ALPO99
Sounds like the fuel pump which is located inside the fuel tank. Depending on the model might be the expensive pump and these are notorious problems
Sunday, August 3rd, 2008 AT 11:30 AM
