1992 Chevy Astro When engine is at running temp. It will no
BUDE106
  • 1992 CHEVROLET ASTRO
  • 6 CYL
  • AWD
  • 200,000 MILES
This vehicle starts up in the mourning, and runs good all day if not shut off. When I shut it off the engine gets spark for a second, and then just cranks. After it sits for a long time it will start again.
Sunday, May 24th, 2009 AT 9:13 AM
MERLIN2021
  • 17,250 POSTS
https://www.2carpros.com/first_things/car_cranks_but_wont_start.htm
See if any of this helps...
Sunday, May 24th, 2009 AT 9:25 AM
BUDE106
  • 6 POSTS
Thanks for the Info on why a car wont start. The info is very informational. I am wondering if the ignition moduale could cause the engine to not turn over when hot. Could the ecr valve stick from carbon build up and not give a signal to send spark?
Sunday, May 24th, 2009 AT 10:20 AM
MERLIN2021
  • 17,250 POSTS
More likley a bad module, egr wont kill spark, mods do! Autozone can test it free of charge before you replace it.
Tuesday, May 26th, 2009 AT 2:29 AM
