1997 Chevy Astro trouble starting engine
LOGMAN55
  • 1997 CHEVROLET ASTRO
  • 6 CYL
  • AWD
  • 325,000 MILES
After the van sits for a day or two without running, I can crank the engine and it stutters and stammers but won't keep running. If I pump the gas pedal a bit it seems to help starting the engine. Otherwise this van runs terrific at all times. I live in wooded mountain area at about 2000 ft. Elev. In my driveway is the only place I have trouble starting the engine; when I park overnight at lower altitudes I have no problems.
Wednesday, October 22nd, 2008 AT 9:04 PM
MASTERTECHTIM
  • 4,750 POSTS
This is the symptom of a weak fuel pump. These engines need high fuel pressure and high fuel volume to start, they will run on lower pressure and volume but they wont start. You can try spraying starter fluid into intake for a second and if it starts and stays running it usually means the fuel pump is weak. Hope this helps
Wednesday, October 22nd, 2008 AT 9:11 PM
