1992 Chevy Astro Oil leak
BLEKKZ
  • 1992 CHEVROLET ASTRO
  • 6 CYL
  • AWD
  • 196,000 MILES
I recently developed an oil leak toward the back of the engine. I've also noticed the oil filler tube is loose. Are the two tied together?
Sunday, January 25th, 2009 AT 3:02 PM
  • 109,885 POSTS
Hi:
Chances are either a valve cover gasket is leaking from the rear and running down the back of the engine or the rear main is leaking. You need to get under the van, and look up to see if the oil is coming from up above or only where the oil pan is near the trans.
Let me know what you find.
Monday, January 26th, 2009 AT 9:04 PM
