1988 Chevy Astro turns off
1988 CHEVROLET ASTRO
100,000 MILES • 6 CYL • 4WD • AUTOMATIC
FABIAN1
  • 16 POSTS
Hello please help my astro van turns off when i stop at a light and when i turn it on. Some times it stays on then it turns off, i need to idle it so it doesnt turn off. i changed the spark pluges, put a carbu kit, and cleaned it throughly, also cleaned the dist. cap. the thing is that i drive and it turns off, or i start the van and it also turns off, not all the time please help me. Becuase we are leaving this week in a road trip and we need the van. thank you God bless.
Jun 28, 2010 at 4:47 PM
Check the fuel pressure to rule out a failing fuel pump if okay could be the coil, distributor pick-up coil and ignition control module, also could be the ignition switch.
Jun 28, 2010 at 6:26 PM
FABIAN1
  • 16 POSTS
well i had all things changed and the last thing i did was changed the fuelpump and that was it, i forgot to check the fuel presure, thak you.
Aug 6, 2010 at 2:30 PM
