Code 67, check engine light on?
93,000 MILES • 5.0L • V8 • 4WD • AUTOMATIC
NATHANB40
scanner code 67. neutral/drive switch circuit open.
What does this mean and how do we correct so it will pass smog?
May 3, 2023 at 8:22 AM
  • 110,244 POSTS
Don't laugh, but was the vehicle in park/neutral and the AC off (both front and rear) when the code was found?
Also, could you let me know if there are any symptoms related? For example, will it start normally in park or neutral?
May 3, 2023 at 1:00 PM
NATHANB40
Vehicle in park, A/C off and yes it starts in park.
May 3, 2023 at 1:03 PM
  • 110,244 POSTS
Are there any symptoms? Is the vehicle doing anything that seems out of the ordinary?
May 4, 2023 at 11:49 AM
NATHANB40
runs well.
May 4, 2023 at 4:02 PM
  • 110,244 POSTS
If it is running well, I would delete the code and see if it comes back. It could have been set in error.
If there are no symptoms, this is what I would try first. I wish I had a better answer, but that is where I would start.
Let me know if you have already done this or what you find.
May 5, 2023 at 2:59 PM
