The thing seems to do this worse when it is really cold outside but it will start and drive then at low speeds predominantly the check engine light will come on and the transmission will shift up or down UN-neccessarily and continue doing so untill i gas on it? very strange i suspect it to be ECM issues but the air temp making it worse makes me think otherwise....input please!!!!! it is the E4AOD trans.
Jan 23, 2014 at 2:40 PM
