1994 Ford Bronco check engine light
BONO BRONCO
  • 1994 FORD BRONCO
  • V8
  • 4WD
  • 95,500 MILES
2 weeks ago when it was really cold like 18 degrees the check engine light came on for about 3 miles and shut off and didnt come back on till next day and did same thing then today it wasnt that cold and it came on for about 5 miles and shut off what can be the problem? My fluid levels are good thank you so much I really appreciate it.
Tuesday, February 12th, 2008 AT 6:57 AM
You need to have the OBD2 code/s pulled at Autozone and comeback with the code/s so we can start the diagnosis
Friday, February 15th, 2008 AT 12:13 AM
BONO BRONCO
  • 18 POSTS
Autozone set they didnt have a tester for the bronco because it is an obd I so I went to advance and bought an obd I and the code came back anout the egr valve and throttle position sensor too high voltage so what can this mean? I thank everyone that can help
Thursday, February 21st, 2008 AT 10:46 PM
